Hello everyone,
Long time member here but my first post.
I have a Whiteside Bowl & Tray bit (1374) which I find excellent however I've been getting some unusual results lately with some of the bowls I've been cutting out.
My question is where, or does it matter what branch in the Tool Database I should located it?
Currently I have it setup as a End Mill however I was wondering if it should be a Ball Nose of something else?
Appreciate any suggestions.
Bowl & tray bit - Database category?
- Model of CNC Machine: JazzCNC Custom Build
When all is said and done, more is said than done
Re: Bowl & tray bit - Database category?
What do you mean by unusual results? If the bit was working fine & now you seem to be having problems then is it time for a new one or to sharpen the one you are using
Generally speaking a bowl bit would be entered in the tool database as a radiused endmill or a form tool
Thanks for the reply.
I didn't want to dwell to much on the "unusual" results as I know its a matter of tweaking the stepover. However I always had a niggling doubt over what the category should be...
And you've kindly answered that!
Thank you
Thank you
- sharkcutup
I typically setup the Bowl Bits as a Form Tool as that provides the program (V-Carve) all the necessary data about the bit to perform well. But you must create an accurate drawing of the bit in order for it to work properly.
Another thing that I do to increase the longevity of the Bowl Bit is to Hog out the bowl pocket first with an endmill leaving a layer/pass for the Bowl Bit to finish up.
Just a few thoughts!!!
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- SteveNelson46
I do the same as Sharkcutup. Bowl and tray bits are actually a radiused endmill but setting them up as a "Form Tool" seems to work better and gives me a picture of the shape when selected. I'm using one on my current project. I made one for a friend a while back and now everybody wants one. This one is the 5th. They're just a simple one day project but fun to make. This one still needs a little sanding and doesn't have a finish applied yet.
Setting them as radiused end mills would be quite convenient. But I'd probably enter one as a form tool only because, in my experience, the curved portion of the bowl bit is generally not a 1/4 circle. It's more like a 1/4 of an ellipse. The same holds for most round-over bits.
Thank you everyone for your help and tips.
Great idea about hogging out with a big end mill first and then going in with the bowl bit.
I went to the Whiteside website, downloaded their tool database and imported in to my one in VCarve - from there I was able to choose the exact tool from their listing. It was specified as a Ball Nose Form Tool and had the profile already provided.
I've tweaked the specs for my machine and is working well!
