Chamfer tool Path
JMOlshefski
Model of CNC Machine: CNC Shark II
Chamfer tool Path
Post by JMOlshefski »
I am making a WW2 Jeep Model from Toys & Joys. I am cutting the hood which has a height of 3 1/8 by width 4 Inches. The thickness at the top of the height is 5/8 and tapers down to 1/2 at bottom how do I chamfer down the 1/8 over the length of the 3 1/8. I tried multiple options in chamfer tool path and just cannot seem to get it?
joe
ohiolyons
Re: Chamfer tool Path
Post by ohiolyons »
We really need to see some photos.
Posting the file would help too.
My guess is your jeep hood is a 3d component and the chamfer toolpath only works on vectors.
The "angled effect" will have to be accomplished with Roughing and Finishing toolpaths.
Only a guess with info provided.
EDIT
So did you buy the pattern and parts list?
Is the pattern paper only?
Is there a STL involved at all?
If no STL how are you making this?
Just flat parts or are you creating 2d parts?
You are using VCarve so advanced 3d modeling will be an issue.
John Lyons
CNC in Kettering, Ohio
Presumably it's the patterns for this model - https://toysandjoys.com/98-ww-ii-milita ... ailer.html
Phil
Post by Phil »
I've found that some pieces like this are fairly easy to make with traditional woodworking tools. If you have a router table rounding the corners would be simple.
Phil
dealguy11
Post by dealguy11 »
I think what you're asking is how to taper the hood down 1/8" from the windshield to the grill, ignoring for the moment how to round over the edges. You could cut that taper with a moulding toolpath. Can't give you any hints for the chamfer toolpath as I always use a moulding toolpath for chamfers that can't be cut directly with a v-bit.
Steve Godding
JMOlshefski
That exactly it, not worried about round over sides,, how would I set up the molding tool path?
dealguy11
Post by dealguy11 »
See example. All the parts/vectors of the toolpaths are in separate layers to help identify them.
Jeep Hood.crv
(126 KiB) Downloaded 21 times
Steve Godding
JMOlshefski
I have v-Carve desktop and cannot open fil?
JMOlshefski wrote:
Mon Mar 13, 2023 4:14 pm
Which version of VCarve do you have? The file will need 11.504.
JMOlshefski
OK thanks I have 10.5
JMOlshefski
Thanks I finally upgrade :)
