Just started using them…. They are great.
My question is the only way to make a sheet active is from the tool path tab?
Can you make any sheet active from the sheet tab on the drawing side of the screen.
Sheets
Re: Sheets
You can double click a sheet in the 2D view to make it active or use the Sheets tab itself to select the active sheet.
