How do I adjust the software to give me a smooth output on the screen the icons and when I do a filet on corners it looks low res. My computer is running Windows 10 pro and my screen res is 3840 x 2160 everything else on my monitor looks great except this program I just upgraded to 11.5 and I needed to get this new computer to run the VCarve pro software as my CNC is running XP for Mach3. For the life of me I know this is a simple fix and I have tried playing with the res on windows and on the TV that I am using for a monitor I have the Dell Optiplex 7050 with 16gb of ram plugged into the TV using HDMI cable. Any help here would be mots appreciated.
Low Res screen
- Model of CNC Machine: Xzero Raptor 30" x48"
Re: Low Res screen
Check for driver updates for your graphics card.
Next:
Select Edit/Options
Under the 3D view settings try different values for Anti-Aliasing
Also see if you get different results using the software renderer
Next:
Select Edit/Options
