Podt processor with rotary axis as B
I am adding a rotary axis to my cnc with Mach3. A is slaved to X. So my rotary axis is B. The processors I see only refer to A. Is there one that would be wrap Y2B? or can I edit an existing one? Thanks,Tommy
Re: POST PROCESSOR WITH ROTARY AXIS AS B
Edit an existing one and change A to B
do I change every A I see to B? looks kind of confusing to me.
Using the post processor Mach2_3_Wrap_X2A_ATC_inch.pp as an example
On line 23 it currently shows
change it to
On line 31 it has:
change it to
Save the file as
Mach2_3_Wrap_X2B_ATC_inch.pp
Code: Select all
POST_NAME = "Mach2/3-WrapX2A ATC(inch)(*.txt)"
Code: Select all
POST_NAME = "Mach2/3-WrapX2B ATC(inch)(*.txt)"
Code: Select all
ROTARY_WRAP_X = "-A"
Code: Select all
ROTARY_WRAP_X = "-B"
- Mach2_3_Wrap_X2A_ATC_inch.zip
- (1.51 KiB) Downloaded 17 times
thank you very much.
- Leo
Tommy,
Can I ask
Why does it need to be called B
Can I ask
What should I use to make the changes? I tried using Word but then I can't save it back as a .PP file.
NotepadWhat should I use to make the changes? I tried using Word but then I can't save it back as a .PP file.
- Leo
I use Mach3 and A is the 4th axis.
I have a dedicated seperate drive for rotary so I do not swap axis's Still it is A
I think you may be able to change it in Mach 3 settings, but I am not sure exactly where.
GER21 is the Mach3 guy.
Have you asked the question on the Artsoft Mach3 forum?
Do you have A slaved to X or YLeo wrote: ↑Wed Mar 08, 2023 10:11 pmI use Mach3 and A is the 4th axis.
