I'm trying to carve out an eagles head into a circle about 3" in diameter. I review the rough and there is a flat spot on the top middle of the cut. I add the preview of the finish cut and the flat spot is still there in preview...??
I have set the model position in material to 0.1232 but the flat spot still shows up in the preview. I tried a cut and the flat spot is definitely there...???
It says the .crv file is too big to send as an attachment.
3D Problem
- Model of CNC Machine: Piranha FX
Re: 3D PROBLEM
If the file is too large to upload here you can use a file sharing site such as drive.google.com, onedrive.com, or dropbox.com. They all have free accounts available
On many Windows systems you can also use <Windows-key><Shift><S>
- Upload the file to the file sharing site
- Make the link shareable
- Share the link to the file here
Re: 3D PROBLEM
Try adding a zero plane if you don't have one. After you moved the models position in the material did you recalculate the toolpaths?
- sharkcutup
Re: 3D PROBLEM
If you are still getting a flat spot that means your model is not sufficiently below surface of material board being carved. Lower the model a bit more until flat spot disappears.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Re: 3D PROBLEM
Review this tutorial video Vectric provides:
https://www.vectric.com/support/tutoria ... hed-recess
This explains the use of the Multiply combining mode in order to address this very problem of placing objects in a dish and avoiding flat spots.
Doug
Doug
