While tracing a number of items (in VCarve Pro11.504) I've come across times I'd wished for the ability to draw a double line. Yes, I end up offsetting, but then I create more work because now I have to delete the undesired parts. Being able to draw a double line of a desired width would be great!
Is this option available?
Intentionally draw a Double Line.
Re: Intentionally draw a Double Line.
There isn't that I know of, in fact I am not aware of a drawing program that this is available in although I haven't looked at some of them for a long time so that may have changed
If you have a single line drawing it isn't always a lot of extra work, depending on the drawing you have you can offset both inwards & outwards at the same time with the box checked to delete the original
- FabLab Wageningen
- Model of CNC Machine: Ooznest Workbee 1500x1500
InkScape does make double lines when tracing thick (wide ?) original lines. Would that be of any help to you ?
Marcel.
Marcel.
