using pocket won't calculate
- Model of CNC Machine: Longmill MK2
using vcarve pro, using the video almond as a guide, after using pocket ,i hit calculate and receive the following message: the following tools produced empty tool paths. they may not be able to fit anywhere the previous tool could not with their current parameters. i get the same message 1/8 or 1/4 end mill down cut tools
Re: using pocket won't calculate
Welcome.
You really need to attach the file you're using to get 100% correct help but that message is telling you the problem.
There are many causes such as having a tool defined differently to what you expect, errors with vectors and sometimes it's just telling you that there is no point in using a smaller bit as the larger bit has already done the work.
Can you upload your file (.CRV or .CRV3D) to the forum?
To upload a file or photo click on the Upload attachment button below the message area
Click on Choose File and select your file
Finally, click on Add the file to upload it to the forum
If the file is too large to upload here you can use a file sharing site such as drive.google.com, onedrive.com, or dropbox.com. They all have free accounts available
On many Windows systems you can also use <Windows-key><Shift><S>
- Upload the file to the file sharing site
- Make the link shareable
- Share the link to the file here
