a little problem
potl
Model of CNC Machine: Nigthhawk cnc
a little problem
Post by potl »
Hi
I run into a small problem when I have to mill a flat surface on this plate. I've always done it this way offset the diameter and made a pocket toolpath, but get an error message??
What is this?
skjærefjøl.crv
(19.5 KiB) Downloaded 16 times
FabLab Wageningen
Model of CNC Machine: Ooznest Workbee 1500x1500
Re: a little problem
Post by FabLab Wageningen »
I all fairness, I don't even understand the error message...
Is it me or is the message text unclear ? It refers to multiple tools ('The following tools', 'they') but you only seem to have specified one ?
Marcel.
potl
Post by potl »
yes ,but i find a upload the tool once and then it worked out nice
You have the diameter of the tool set to 27 inches.
adze_cnc
Post by adze_cnc »
Your ramping length is set at 25mm which is only 2/3 the diameter of the cutter. That might not be enough. If it was me I’d probably set it at 2 or 3 times the cutter diameter (e.g. 76 or 114mm).
