Creating a lip or recessed profile cut?
- Model of CNC Machine: AXYZ
Trying to think through the logistics of a project I want to do which is going to need a portion of a profile cut to be 1/8" recessed from the rest of the profile cut such that it's singular piece and not two separate pieces.
Can anyone help point me in the direction of such an initiative?
Thank you.
Cheers
Thank you.
Cheers
- dealguy11
Re: Creating a lip or recessed profile cut?
Can you provide a sketch of what you're trying to do?
Steve Godding
Hi and thank you for the reply.
Attached two images.
This would be looking at it from the X axis
This view would be if looking at it from the Y axis
Basically its all one piece but an area of the piece is cut at a lower depth than the other but cannot be cut as two separate parts... they need to be a singular piece.
Not sure if that made sense?
- sharkcutup
Something Like This???
**** Question: When you say PORTION ---- How much of a PORTION is to be 1/8" recessed from the rest?
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Yeah something like that. Recessed section will be about 18.5"x5.5" and the other section will be about 2.25"x7" with a z height difference of 1/8th between the twosharkcutup wrote: ↑Sat Jan 21, 2023 12:46 amSomething Like This???
Sharkcutup
- sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Yessir minus the raised outside boarder
So the sketches posted above are only half the object and should be mirrored to show the full cross-section?
- sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Yessir. That's basically what I am trying to accomplish. Not the same design obviously but having a section of the material that's above the rest of the material. Looks like you got the jist of what I was looking to do.sharkcutup wrote: ↑Sat Jan 21, 2023 8:25 pmAlright Like This.png
Alright Then Like This?
Sharkcutup
Is that a moulding too path?
- sharkcutup
Nope!
A 1/8" Roundover Bit ON the Vector set to 1/8" deep after pocketing the outer perimeter. Easier and less time in carving!!!
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
so how does that work for something that might look like the attached?sharkcutup wrote: ↑Sat Jan 21, 2023 10:05 pmNope!
Sharkcutup
I can't apply a pocketing toolpath to the side that's 0.875 because vector is open and closing it would mean having two separate pieces, no? I feel like I am analyzing this lol
- sharkcutup
Two Toolpaths used Pocket - Closed Vector and Profile On an Open Vector Tri
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
No idea what any of that means lolsharkcutup wrote: ↑Sat Jan 21, 2023 11:27 pmAnd Again.png
And again
Sharkcutup
- sharkcutup
Three Actual Toolpaths Used --- These are the "Settings" I used!!!
1.) Hog out --- Pocket ToolPath .25" Endmill
2.) CleanUP --- .125" Endmill to cleanup Both at .125" deep Offset Cut Direction "Climb"
Inside a Closed Vector - Pocket ToolPath
3.) Profile ToolPath with a .125" Pointed Roundover Bit Machine Vector -- "ON" Direction "Climb"
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
