Tiling question
- Model of CNC Machine: next wave shark 520
Tiling question
this is one of my biggest signs yet and I have tried over and over to move the letters around so they are not in the "split". I just can't seem to make it look right. Any suggestions or am I just freaking out about the overlap? or both... ( I had to delete the tool paths to be able to send it, The tile size is 22X44)
- BAR AND GRILL 2.crv
- (74.5 KiB) Downloaded 42 times
I try to learn something every day
- FabLab Wageningen
- Model of CNC Machine: Ooznest Workbee 1500x1500
Re: Tiling question
Do you want to tile horizontally or vertically ?
What I see is a bit odd (sorry). The top text seems correctly set on a circular vector, the bottom text not. The 'U' in the bottom text seems a bit out of position. Also the two circles are not totally parallel / offset. Is this the good file at all ?
If I were you I would already put a tile border in your design program. Easier to see and work. Did you design this in VCarve Pro ?
Marcel.
Marcel.
Re: Tiling question
To follow up on Marcel's notes (which came in while I was fiddling about). How about this?
- Blue circle was set at top and bottom of existing text
- From that I noticed "One..." and both of the curved lines of text could be moved left to better centre
- Artwork rotated -3 degrees about the centre within the circle
- Guideline is at 23.25 inches
Re: Tiling question
I was called into work so I will try and work on it a little bit more when I get home but I appreciate the suggestions. Marcel, I made the gap larger between the view in a I will fix that also
Re: Tiling question
yes I did this in vcarve pro I was trying to manipulate the text to work with the tile and it looked goofy as you say.... Here I tried again this time I didn't try to manipulate anything but I have plenty of text in the tile area. once again in need a tile 22X44FabLab Wageningen wrote: ↑Tue Nov 29, 2022 8:26 pmDo you want to tile horizontally or vertically ?
Marcel.
- BAR AND GRILL 4.crv
- (80 KiB) Downloaded 23 times
- FabLab Wageningen
Re: Tiling question
Your new design looks much better,
Steven, obviously, has the right - though somewhat fiddely - solution for you, but I (lazy designer) wondered: is this design not easier to do with 3 horizontal panels ? One with the 'bar & grill' text, one with 'one - 80 - six' and the bottom with 'marquand mo'? No splitting of text at all. Just a thought.
Marcel.
Marcel.
- sharkcutup
Re: Tiling question
Here is my attempt!
Sharkcutup
Interesting Suggestion There FABLAB!!!
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
Re: Tiling question
I love how you think!!!!FabLab Wageningen wrote: ↑Wed Nov 30, 2022 9:39 amYour new design looks much better,
Marcel.
Re: Tiling question
did I mention I still have 10.5? maybe I should just go and bite the bullet and upgradesharkcutup wrote: ↑Wed Nov 30, 2022 10:08 amHere is my attempt!
BAR AND GRILL 4.crv
Sharkcutup
Re: Tiling question
i had to bite the bullet and upgrade, I didn't want to spend the money right now but isnt that what credit cards are for?sharkcutup wrote: ↑Wed Nov 30, 2022 10:08 amHere is my attempt!
BAR AND GRILL 4.crv
Sharkcutup
Re: Tiling question
Marcel I took your advice and tried vertical tiling since my x axis is too small for the 44 " project. I took and spun the whole thing 90 degrees and tile it at 14.75" and waaaaall ahhhh.
thanks to everyone who contributed....it takes a village sometimes
happy carving
happy carving
- (80 KiB) Downloaded 25 times
- sharkcutup
Re: Tiling question
If only I had known, lol!!! SORRY!!!
I still have that version on my laptop computer.
Not anywhere near it at the moment but when and if I remember to I will send it again in that version if you are still interested in seeing it.
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
- sharkcutup
Re: Tiling question
Okay wow!!
You will enjoy the New features that have been added!!!
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
Re: Tiling question
My brother talked me into doing a practice piece for another large tiling project I'm working on. I want to try the overlap feature to see how it works before I carve the 24X144 sign. how do you find XY zero when you move the project? just work off the XY zero from the first pass by drawing a line for your starting point? that is how I was going to do it but I wanted to check and see if I'm heading in the right direction before I start carving on $200 worth of lumber..
the 186 bar and grill sign is in glue...
- sam sample.crv
- (789 KiB) Downloaded 22 times
