I need to make some table legs for an island. I have a 4th axis for my CNC which I've never used, and I'm thinking this is a perfect way to get going...
I'm wondering if someone can point me to a good video tutorial on this subject. I've seen some with wrapped text, carved leaves and other things, but I need to be able to do a leg that you'd normally see come off a lathe.
The legs I'm looking to do are similar in style to this: https://www.tablelegs.com/country-shera ... 2-75-x-18/
Thanks in advance for any help with this.
-Bob
Rotary Machining
- Model of CNC Machine: Shop Sabre 510 Pro
Re: Rotary Machining
Here is a starting point:
Here is the link to Vectric's Rotary training : https://www.vectric.com/support/tutorials/aspire
I've only played with the 4th axis a little but I believe the moulding tool path is going to be the best option to recreate a leg like that. I could be wrong as I don't have much experience with the 4th axis.
- SteveNelson46
I did this all in Aspire. It still needs some work.
https://drive.google.com/file/d/1oVKIr0 ... sp=sharing
Moulding toolpath done in VCarve. If you used a square blank the unmachined areas would be square.
- TableLegMoulding.crv
- (1.06 MiB) Downloaded 40 times
- TableLeg18Vector.ai
- (3.99 KiB) Downloaded 24 times
