VC11-Downloading FishingVillage
- Model of CNC Machine: CNC Shark Pro Plus HD Routing System
I am missing something on downloading the fishing village into V-Carve 11. Once I hit download and the little window comes up in lower left corner, instead of being a ZIP file it goes to install, (.exe File) I tried that but still can not open. I did try another free model from Vectric and that came in as a ZIP file and works.
Re: VC11-Downloading FishingVillage
If it's an installer (exe) then when you run it (double click the file) it will install and tell you where it's been installed in a pop up.
Thanks for the info. Oh my! I knew it had to be something simple! Try opening up VC-11 and click on side tab marked (clipart) and everything on Waterside Fishing Village is there
