Hey guys, sorry if this has been covered. I tried searching and watched a few different tutorials, but am having trouble getting some simple text to conform to a 3d shape. A 24" ruler I made as a prototype for a different project. Whenever I generate the toolpath it assumes the z top to start rather than conforming to the milled portion.
What am I missing?
(probably) a simple problem with project toolpath to 3d shape
- ruler test.crv
- my project file
- (367.5 KiB) Downloaded 24 times
Re: (probably) a simple problem with project toolpath to 3d shape
Project Toolpath onto 3D model works with 3D models only. A moulding toolpath is not a 3D model.
You would need to create a 3D model of the ruler (with external software as you have VCarve rather than Aspire) and use that.
Alternatively you could make a jig to hold the completed ruler so the portion you want to engrave is horizontal rather than at an angle.
I expect there will be lots of other ideas on how to do this as there is generally multiple ways to do every job with VCarve.
I see, ok thanks. In aspire is there a way to "convert" a molding toolpath to a 3d model I could then project the text onto? I'll upgrade if that makes it easier. I'm only familiar with sketchup
In Aspire you can make a 3D model directly in various ways with a shape like that (a sweep would be easiest) and you can even create a model directly from a toolpath preview.
You can download the trial and see what you can do before having to part with any cash.
Thanks for the quick replies! Thats awesome! I imported a simple stl from sketchup just to see how it works, and it did exactly as you said. I'll do some research into aspire. Loving vcarve pro in general, and I appreciate this forum.
Jon
Jon
