3D preview
- Aussie
- Model of CNC Machine: Robotics Model 8
3D preview
Is it possible to display rulers and guidelines in the 3D preview, this would come in handy when placing keyholes on the bottom side of a model so you know the thickness of the material you have available.
Ron
Crafers Crafts
Crafers Crafts
Re: 3D preview
The co-ordinate system is the same in the 2D window and 3D window so if you look on the status bar at the bottom you can match up X and Y positions once you've found a Z thickness (also displayed in the status bar) that does the job.
- Model of CNC Machine: CAMaster Stinger II
Re: 3D preview
Would using the ruler tool and checking the model cross-section button help get what you need?
Charlie
Aspire, CAMaster Stinger II
- Aussie
Re: 3D preview
Thank you Adrian
Yes that will work… still think the guide lines would be helpful and turn them off if you want to.
Ron
Crafers Crafts
Crafers Crafts
