Saving files
Jan.vanderlinden
Model of CNC Machine: Xcarve
Saving files
Post by Jan.vanderlinden »
Is there a way to save a file in an earlier version of Vectric?
I have V11 and would like to save it in V10 so my friend can read it in.
Re: Saving files
There is no way of saving an older version file with a newer version.
You would need to export the vectors using the export option on the File menu and any models as STL files instead.
adze_cnc
Re: Saving files
Post by adze_cnc »
no down-saving has ever been possible
You could, possibly, export vectors to dwg, etc. and save toolpath template then re-import in lower version. It might work but I’ve not tried.
Jan.vanderlinden
Re: Saving files
Thank you both.
I will give it a try.
