Box Creator Gadget Problem.
ElderlyGent
Model of CNC Machine: Piranha FX
Post by ElderlyGent »
Good morning all
Recently I upgraded tp Pro from Desktop, and very nice it is too, but the other day I wanted to set up the BoxCreator to test some joints ie Finger Joints. It would not work,
I set up thje worl area and in the past I could then click on the box cretor tab and then I could define the size etc of the box to be made.
All I got is a message ,see attachement.
However the Dovetail Gafget works fine,
Any pointers to cure this will be greatly appreciated.
Regards
Drew aka EG
Re: Box Creator Gadget Problem.
You've got the wrong version of the gadget. You will get that error if you try to use a pre-V10 version with V10 or later.
The correct version can always be downloaded from https://gadgets.vectric.com and the direct link is https://gadgets.vectric.com/V11/box_creator
ElderlyGent
Many thanks for your help. That solved the problem. It seems to be working fine now.
