Engrave Test
Aussie
Model of CNC Machine: Robotics Model 8
Engrave Test
Post by Aussie »
This was engraved on 2 ply plastic with an Amana 51515 0 flute 1/16 EM, Quick engrave Toolpath DOC 0.3mm
Finished item will be engraved on Rowmark Glow 2 ply plastic, it is stated the engraving will glow for a minimum 90 minutes after lights out.
Should be good for the grand children's bedrooms.
Will post the final result with the glow material arrives.
Ron
Crafers Crafts
Re: Engrave Test
Post by scottp55 »
Personalized, relatively quick, flat pack storage, and kids Like "Glow-in-the-Dark stuff"! :)
I think you hit a bunch of points there Ron for pre-Christmas gifts.
In US, Centurion tools makes a bit Just for color core, Old Shopbot teacher TJ swore by them;
https://www.centuriontools.com/collections/engraving
Good idea Ron!! :)
jerry carney
Model of CNC Machine: shopbot desktop
Re: Engrave Test
Post by jerry carney »
Hey, where did you get the Rowmark 2 ply plastic? Thanks JERRY
Re: Engrave Test
Looks good to me & as someone has said kids love glow in the dark stuff :lol: :lol:
Are you using a nose cone or just double-sided taping or ca/taping the workpiece down?
I had problems machining engineering laminates until I started to use a suitable method of hold down as it tends to bow up in the middle when clamped around the edge :lol: :lol:
Re: Engrave Test
jerry carney wrote:
Sat Oct 23, 2021 3:07 pm
Not sure where you are in the world but try a google search for engraving laminates, Rowmark should come up at the top or very close to it :lol: :lol:
Aussie
Re: Engrave Test
Post by Aussie »
Rowmark I believe is a US company with a branch in Sydney…. Delivery is normally 2 to 3 days.
Ron
Crafers Crafts
Aussie
Re: Engrave Test
Post by Aussie »
martin54 wrote:
Sat Oct 23, 2021 3:20 pm
As the material is 1.27mm I use a vacuum table or tape method…if I am too lazy to setup the vacuum, I did resurface my spoilboard for this job.
I tried a 0.1 pressure and found the cut was not even across the whole surface, 0.3 gave me a good result, will change the font in the next effort for a better “e”
Ron
Crafers Crafts
Aussie
Re: Engrave Test
Post by Aussie »
scottp55 wrote:
Sat Oct 23, 2021 8:20 am
Good idea Ron!! :)
Thanks Scott I will check out the link.
Ron
Crafers Crafts
Re: Engrave Test
Not sure where Rowmark are based, I do know their laminates are sold around the world :lol: :lol: I use some of their products for indoor & outdoor signs which is why I asked what hold down method you used. I made a small vacuum fixture to keep it flat while machining. Will have to look into the glow in the dark stuff as I don't remember seeing that, bit late for Halloween this year unfortunately but maybe next year :lol: :lol:
