Hello all
Im after some advice on tool selection for fine text carving, I have the following tools...
https://www.toolstoday.com/global/v-144 ... 177-k.html
I am trying to carve small but each time its coming out quite rough.
I am using the single line font choice in Vcarve.
Thankyou
Tool selection
- Model of CNC Machine: LEAD CNC
Re: Tool selection
What is the material? Some woods will always leave a rough finish without treatment first.
Also you might be using the correct tool but with the wrong feed rates.
Generally I cut single line text with a 30 degree one of these Wealden Tool bits but a lot depends on the size of the text and the look you want.
Re: Tool selection
There are quite a few different factors to consider when cutting text no matter what type of toolpath you are using. Try a search on the forum as it is something that has been spoken about quite a bit so all the answers you could possibly seak are already on the forum
This PDF someone put together is aimed at v carving but it will still apply to what you are trying to do
viewtopic.php?f=3&t=37067&p=270569&hili ... xt#p270569
Re: Tool selection
Cutting plywood, pine and vic ash.
I will redice my feedrate and see if that helps, thankyou for the link as well, its defo helped!
Re: Tool selection
Never machined pine, plywood has lots of different types so may depend what type of plywood, Ash can be problematic, at least here in the UK the ash that I buy can be
Dense hardwoods are always going to be best for very fine detail & text
