I needed to cut a French cleat on a piece. I used a 90 degree v-bit with a moulding toolpath. It took forever to cut.
What is the most efficient way to put a French cleat (.e.g 45 deg profile) along the edge of a piece?
Thx,
French Cleat - How to efficiently cut?
Re: French Cleat - How to efficiently cut?
Depends on the dimensions, the size of bit available, how many are being cut in one go and a few other factors that I probably haven't thought of.
The most efficient way is to use a profile cut with the 90 degree bit so you end up with two pieces with a 45 on them (unless you're cutting on the edge). Material size and bit size comes into it a lot though.
Next most efficient would be to draw a rectangle and use a v-carve toolpath which would get around bit size problems.
As for the moulding toolpath it would probably have been more efficient to use a ballnose or endmill. Stepover plays a big part in the speed of that toolpath as well.
Pictures help
Adrian can't give you the best answer because he doesn't have enough detail to be able to do that & for me the most efficient way to cut one would be on a table saw & attach one half to the work piece but that's not the answer your looking for
Definitely table saw.
Phil
Phil
- dealguy11
I'd also use a table saw for this. If you have to use a CNC, then a profile cut, on the vector, with a 90-degree vbit would do it, assuming your machine can run a 90-degree bit with a wide enough diameter to cut through. If you're cutting 3/4" material you'll need a bit with 1 1/2" diameter.
Steve Godding
Thank you all for the replies.
Yes, in the future I would likely use my router table since the piece is too small where I'd feel comfortable on the table saw.
The piece was only 19" long and 1/2 inch thick.
I'm a newbie trying to learn how to use the different bits for different profiles/toolpaths.
Thx again
Thx again
When you are using a table saw it's important to make cuts like the 45 degree angle cut while the board is still wide enough to manage safely followed up by cutting the part to size. I hope that is clear.DaddyFox wrote: ↑Tue Sep 21, 2021 11:42 pmThank you all for the replies.
Thx again
Phil
