Running 2 post processors vcarvepro
I have a new wave shark and a digital wood carve machine. Since I started running version 11 even after installing shark processor I cant bring up the tap file for the shark machine. The dwc does ok but the shark cant pull the tap file up
Re: Running 2 post processors vcarvepro
If you are running 2 different machines then you would be best setting up 2 different machine profiles which are independant of each other. Easy enough to add a new machine & then when you do your saving of toolpaths you just select the machine you want to use & the relevant post processors will be available
