I just purchased a Whiteside SC50 22 deg bit to do some inlay work. I am setting it up as a VBit. Any advise on the tool database settings? This is what I have right now.
Whiteside SC50 Tool database?
Re: Whiteside SC50 Tool database?
Speed & feed settings will be down to your own machine but a quick google search showed it to be a single flute bit
Whiteside has a vectric tool database that should be a good starting point at link below:
https://www.whitesiderouterbits.com/pag ... tool-files
If you drill down you can select specific tool, or you can download the entire file with all of their tools if you scroll to the bottom of the list.
As Martin said, speed and feed settings may need to be changed to fit your machine capabiities.
