V.11 Moulding TP glitch..?
- Model of CNC Machine: shopbot standard gantry 4896
I recently upgraded to VCP to11.007 I am currently running Moulding TP. I selected 'larger area clearance tool' with it being tool #2. For the primary tool I number it as tool #3. They are in that order when I select run TP. My machine skips 'clearing #2' and goes directly to primary tool #3. Anyone having similar issues? Any assist will be appreciated.
Re: V.11 Moulding TP glitch..?
How are you saving the toolpaths? Do you have the options correctly set for saving multiple toolpaths at the top of the form? A common issue when upgrading is people forget to check those settings.
