Trying to carve a two sided object but the level of the slpit between first and second side needs to be significantly off horizontal.
I cannot find how to do this.
Model is 100mm z height
The logical line to seperate the two sides would be 60mm z at one end and 32mm z at the other.
Is this possible? . . and if so, is the a tutorial that covers this aspect?
I tried to attach the file but it says "Error file too big"
Thank you
Russell Ferriday
Two sided level of split
- Model of CNC Machine: Self built
- ohiolyons
Re: Two sided level of split
put it on drop box or goggle drive and post a link.
post some photos too.
John Lyons
CNC in Kettering, Ohio
- SteveNelson46
You can try adding a zero plane and tilting it using its properties. As Ohiolyons said, posting your model is always best.
Thank you.
I dont know how dropbox googledrive works.
I will look for info on zero plane.
found some stuff about it but so far nothing about tilting it.
No big deal. I might be a bit thick but I dont give up easy
- ohiolyons
Not saying this will solve your problem, but this is how you tilt or fade a zero plane.
select the Modeling tab
Add zero plane
select the zero plane
select the wrench, about have way down are your tilting and fading options.
Add zero plane
John Lyons
