usb connections
- Model of CNC Machine: Onefinity x-35 with vcarve pro
usb connections
what is needed to connect computer directly to controller to download tool paths? vcarve pro to onefinity woodworker.
Re: usb connections
You would probably be better off looking/asking on the Onefinity support site - https://www.onefinitycnc.com/support
From what I can see there is no direct output option with the post processors for that machine and you would transfer files in the normal way.
Re: usb connections
what is the normal way. i'm new with cnc. I have cut just three projects downloading tool paths onto flash drives and flash drive to controller. Now no data is downloading onto flash drives. It shows the file on the drive with xxxkb of data but their is nothing on the drive.
Don't know what i've done wrong.
Re: usb connections
There is a button right below save tool path "connect directly to machine" but it is not turned on. I thought maybe I needed to install
driver or a patch for my computer to communicate with controller/
- SteveNelson46
Re: usb connections
I have done both, still not betting any data downloaded
- Model of CNC Machine: CWI Professor 2.2
Re: usb connections
Check the name you gave to the file. My machine does not like "." or "/ \" and will act as if the file is not there. Changing the name fixes it.
Re: usb connections
It also could be a file name extension issue. For example if your machine is expecting: abc.nc as a name and the post processor saves it as abc.gcode the cnc machine might not recognize it.
Re: usb connections
That option will only work with certain types of controller & the controller itself needs to be set up correctly from what I understand. As Adrian has said you would probably get better help from onefinity support on how to set that up if it is possible.
You have obviously got it to work at some point if you have completed 3 projects, have you made any changes to your computer or the CNC controller since you completed those projects?
Normally changing the flash drive or making sure you remove it safely from you computer sorts out drive problems.
- AboveCreations
- Model of CNC Machine: i2r B22
Re: usb connections
I too agree with Adrian and Martin that you should inquire with your machine's support at onefinity. But quite honestly, I am curious, why do you want to send your toolpath/gcode directly to your machine? And why via the USB? You stated that you are new to CNC and only completed a few projects, but don't know what the "norm" is?
After I acquired my CNC machine, I spent many weeks trying to familiarize myself with my new machine by just doing very basic projects. Most of them were from Vectric tutorials that I modified to my machine's toolpath data. I would encourage anyone new to do the same. I am sure anyone is anxious to jump into complex projects after getting a new machine. But do realize that you must know your machine thoroughly before doing that. This is just my opinion and good luck.
