Installing Laser Module on Desktop V11.07
- Model of CNC Machine: Next Wave Shark SD120
I just purchased the Laser Module to add to VCarve Desktop V11.07. The online instructions advise to go to Help > Trial - Laser Module to install the module and then add the license. However, the Help > Trial - Laser Module is not an option on Desktop V11.07. Is the laser module not compatible with V11 or is there another means of installing?
- scotttarnor
Re: Installing Laser Module on Desktop V11.07
I’m sure it’s compatible with V11, it is also not compatible with the Nextwave PP, on the product page Nextwave is not listed. and if you search this forum you can read issues others have had with Sharks/Nextwave.
Scott T
@scottscnc
@scottscnc
Thanks, Scott. Looks like I might have to go the "other" tool route as a work-a-round till I get it sorted out. As luck would have it, it is a NextWave laser I'll be using. Brand new to the CNC world and the laser was a promotional add-on.scotttarnor wrote: ↑Sun Sep 12, 2021 11:36 pmI’m sure it’s compatible with V11, it is also not compatible with the Nextwave PP, on the product page Nextwave is not listed. and if you search this forum you can read issues others have had with Sharks/Nextwave.
- scotttarnor
I have limited time on my laser but playing around with Nextwaves ready to raster laser software and getting ok results, I have not dedicated the time to dial in power and feed rates yet.
Scott T
@scottscnc
@scottscnc
Help > Trial - Laser Module is for activating the trial laser module on the trial version of VCarve.Plane Michael wrote: ↑Sun Sep 12, 2021 11:29 pmI just purchased the Laser Module to add to VCarve Desktop V11.07. The online instructions advise to go to Help > Trial - Laser Module to install the module and then add the license. However, the Help > Trial - Laser Module is not an option on Desktop V11.07. Is the laser module not compatible with V11 or is there another means of installing?
If you have a purchased license for the full (not trial) version of VCarve then you go to the Help menu and choose "Enter License Code"
- TomGB
- Model of CNC Machine: SharkHD4
I have a 2 watt Next Wave laser and have used the Next Wave CNC (inch) (*.tap) post processer. I'm no wizzard but the few things I've done have turned out OK. FYI, last week I contacted Vectric staff with a laser question and they said they were working with Next Wave and hoped to have something out in the next fix release.
- Model of CNC Machine: CAMaster Stinger 1 SR-24, Shark SD110
Hi TomGB
These are the post processor files Next Wave Automation's (NWA) support sent me. I have not used my SD120 with Version 11 though. I also have the 2W laser from NBA. Both pp worked the last time i'd used them.
Good Luck,
Brooks
Good Luck,
Brooks
- Next_Wave_CNC_inch.pp
- (5.91 KiB) Downloaded 34 times
- Next_Wave-Laser_inch.pp
- (6.35 KiB) Downloaded 51 times
- How to install Post Processors in Aspire or V-Carve.txt
- (1.83 KiB) Downloaded 50 times
- TomGB
Thanks Brooks
Those aren't post processors for the Laser Module though. They are standard processors for using the laser in the "old" way.
Thank you Adrian for pointing that out.
https://nextwaveautomation.zendesk.com/ ... 0046235651
The above link, is NWA's list of pp compatible with NWA's various machines with links to download the pp.
Hopefully this helps.
Brooks
Brooks
