Inwards offset not duplicating rounder corners
siric
Model of CNC Machine: XCarve 1000mm and OneFinity Woodworker
Post by siric »
Hi,
I have created a 16" square with rounded corners (with a radius of 2"), but if I create an offset 2" inwards and have the Create sharp offset corners unchecked, it produces a square with 90 degree corners. Why wouldn't it be created with the rounded corners?
Leo
Re: Inwards offset not duplicating rounder corners
Post by Leo »
The box got smaller - but so does the radius
2" radius minus 2" equals 0
sharkcutup
Post by sharkcutup »
Just to add to above post ---
You can always add rounded corners like example below
Sharkcutup
V-Carve Pro 12.004
siric
Post by siric »
Yes, I know that I can create the rounded corners on the new square but my thought was that the offset creates a vector that is a facsimile of the original just smaller or larger. Same as me creating a copy and then changing the dimensions.
FixitMike
Post by FixitMike »
siric wrote:
Mon Aug 02, 2021 9:13 pm
No, that is the Set Selected Objects Size tool that does that.
To see what each tool does and how they do it, see Help-Help Contents.
sharkcutup
Yes but the OFFSET tool does an entire (box sides & radius) Dimensional Change in your example box. It is not a Facsimile change.
if you want a 2" smaller box maintaining a 2" radius then you will have to copy/paste then resize the box. Which in this case you would create a new size of a 12" box (2" Vertical by 2" Horizontal = 4" Total) with a final results of 16" - 4" = 12"
ARRRRGH!!! FixitMike beat me to it!!!
Sharkcutup
V-Carve Pro 12.004
siric
Post by siric »
Understood. Thanks
