post processor for Axiom
- Model of CNC Machine: Axiom AR4 V5 Pro
What post processor is used for the Axiom Basic series?? It is not listed
Re: post processor for Axiom
When you say it's not listed do you mean the machine isn't listed when you run the kickstarter? If that is the case then is the post processor you were using previously listed in the post processor list? Do you know what controller it uses as that may help.
If you don't get a reply then probably best to send Axiom a message as they will probably be able to tell you
Or you might get an answer here:
https://axiomprecision.proboards.com/
- Model of CNC Machine: Axiom AR 8 Pro+
My advice is call Axiom and ask for Chad McCarty.
