Another noob question...
I can create tool paths - no problem. But, why when I create a new toolpath for a second cut, the tool database is different.
I've created a few form tools as needed in the database and they are shown as available for selection. When I create my second toolpath and try to select the tool I need, the database is different doesn't show the form tools I've created. (the material selected is the same for each tool selection attempt).
I can provide more detail as to what I'm doing if needed.
Thanks for your help.
Tool Database
- sharkcutup
Re: Tool Database
The Tool Database has been designed with some safety in mind.
If lets say you were to select the V-Carve Toolpath well then Form tools are not allowed to be used here so they do not show. Only V-bits are used hence the name V-CARVE of the Toolpath.
If you click the display tool base icon under Toolpath Operations (fourth row first Icon) it will show all your tools that you have entered.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Re: Tool Database
Thanks for your reply. I was able to follow everything you mentioned, and yes, I see the tools I've created, but I still don't see how to apply a form tool I've created to a new (2nd) toolpath. .
My first toolpath is a profile cut using a Vcarve installed tool - no problem. My second toolpath is a chamfering toolpath using a form tool that I've created. I can't see the tools I've created when I try to select the tool I need for the 2nd cut.
Re: Tool Database
Same reason as the v-carve toolpath. A chamfer toolpath can only use a v-bit or a ballnose. A form tool isn't a valid choice so you can't select it. By default all un-selectable tools are hidden. You can change that by right clicking in the tool selection tree and turning that option off but you still won't be able to select a form tool just see it.
