Hello,
Will the program create a holding tab and when all cutouts have been made come back and cutout the tabs?
VCarve Pro 10- Tabs Cutout
- Model of CNC Machine: Mach3
- jfederer
- Model of CNC Machine: CanCam D23M
Re: VCarve Pro 10- Tabs Cutout
No. The point of adding tabs is to keep loose pieces from flying around. They need to be cut off manually after the CNC work is done. I use a small Japanese-pattern saw.
Joe Federer
www.federer.ca
www.federer.ca
- dealguy11
A different approach that accomplishes something similar is to use a technique called onion skin. Cut everything out leaving a thin skin of material. For example, if the material is 3/4" thick, leave .03" or so of material uncut, or whatever works for you. Then do a second cutout toolpath with 1 pass cutting all the way through.
Steve Godding
