2d Profile Bit Change not allowed
spes
Model of CNC Machine: Onefinity Woodworker
Post by spes »
Hello,
So I am trying to change the selected bit in my 2d Profile Toolpath.
When I choose a different bit it won't let me select it.
Even when I start a new file and go to change the selected bit, it still won't let me change what is already selected.
Stumped. Never did this before.
Re: 2d Profile Bit Change not allowed
Post by martin54 »
What version of the software are you running & if you have upgraded to V11 have you set up the tool database & the machine correctly, do you have speed & feed settings for the bit you wish to change to?
spes
Post by spes »
Version 11
I believe all tool data was carried over.
Newly created file in V11
spes
Post by spes »
I just looked at my tool database. Speeds and feeds not shown. What the heck. I have to re-enter every bit after update? What a pia.
dealguy11
Model of CNC Machine: Anderson Selexx 510,24x48 GCnC/WinCNC
Post by dealguy11 »
You may not have to do this. It threw me the first time, too...was about to panic that I'd lost all of them. Check all the materials for all the machines. It's possible the tool definitions are hiding in one of them. Then you would just rename the machine/material to what you really want it to be.
Steve Godding
sharkcutup
Post by sharkcutup »
Helpful Hint ---
It would also be useful to get in the habit of using a valuable feature that is available to all who have purchased Vectric Software your Vectric Portal via the online button on the Tool Database Reference image below. This a great place to backup your Tool Database!!!
Should you ever loose your Tool Database there will be one here provided you take advantage of this Feature!!!
Sharkcutup
V-Carve Pro 12.004
