Can't select ANY tools in Vcarve Pro 11
FamousElements
Model of CNC Machine: Shapeoko Pro
Post by FamousElements »
Upgraded to Vcarve Pro 11 last night and I'm excited about some of the new features.
So far I haven't had much luck. The Machine Configuration Management page doesn't have an option for a Shapeoko Pro (or anything Shapeoko related) so I created a new machine and added the Shapeoko post processor. I literally have no tools that I can select now. I have all the stock ones and all the Amana ones listed but they are greyed out and I can't select them.
I've tried selecting a toolpath using everything from profile, vcarve, quick engrave and so far nothing. Can't select any tools at all. I even tried opening up an old file with a known good toolpath, everything is there and selected as it was but if I go to edit which tool I'm using they are all greyed out too.
Help?
Chris
Re: Can't select ANY tools in Vcarve Pro 11
Tool settings are associated with the selected Material and the selected machine. Until you have created the settings for that combination the tools will be greyed out.
Select a greyed out tool and the Copy Settings From section will appear. Click Copy and change any settings you need and you're good to go for that tool.
It's the same way that it worked in V10 as well but if you didn't change materials/machines you might not have noticed.
mohamed
Vectric Staff
Post by mohamed »
Can't tell what other machines you have there, but you must have been using a machine in V10.x. It might just be easier to rename your existing machine and adding a post-processor to it, as opposed to creating a new one and setting up all the tools for it?
Mohamed
TomWS
Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Post by TomWS »
FamousElements wrote:
Sun Jul 25, 2021 2:56 pm
I installed V11 yesterday and one of the things that greatly pleased me is that, during the installation, I was given a choice to migrate my V10.5 tools, post processors, etc, to the new installation. Very handy. I don't know if you can launch this after the fact, but I highly recommend this step.
FamousElements
Thank you for the help!
I did what you guys suggested and just took one of the machines that worked, copied it, renamed it, and added the appropriate post-processor to it.
Now to figure out how to get certain tools into certain operations. For instance I see a 'diamond drag' tool in 'quick engraving' but not in 'v-carve / engraving toolpath'. I figured that might be the right tool for the job but I might just try and create a vcarve bit with similar dimensions to bypass the headache. I added a vinyl cutter attachment to my machine and it's leaving tabs when I do 'quick engraving' like the tool doesn't quite return to the original entry point. Was hoping to maybe try it with the 'v-carve/engraving' toolpath so I could potentially add some lead out but I'm coming up short.
Not all tools can be used with all toolpaths. For a v-carve toolpath, for example, you can use v-bits and ballnoses only.
From what you're describing you should be using a profile toolpath, a v-carve toolpath isn't gong to work with a vinyl cutter even if you use a dummy tool.
FamousElements
I think I might have figured it out.
I used just a profile toolpath with the dummy of a 1/32 endmill, created some lead in/out with overlap and it cut PERFECTLY.
