Ramps and Tabs
jenordyke
Model of CNC Machine: OneFinity
Ramps and Tabs
Post by jenordyke »
Today I was working on a much larger project than any previous...I needed fairly thick/robust tabs on profile cutout, and something didn't "sound right"...that's when I realized for the first time that ramping only appears to apply to the very beginning of a cut at a specific depth; the sound I was hearing was the bit jamming down into the wood on the 'far side' of a tab. As I am pretty new to Vectric Pro, am I missing some setting or check box so that I get a ramp when the retracted bit reaches the far side of the tab? It only seems logical this would be possible - the need/reason for ramping remains whether you need to ease in at the very start of a cut or in the middle of a cut......
Re: Ramps and Tabs
Post by martin54 »
if you need the bit to ramp where you have placed your tabs then you will need to check the box that says 3D tabs :lol: :lol:
adze_cnc
Re: Ramps and Tabs
Post by adze_cnc »
jenordyke wrote:
Sat Jul 24, 2021 9:06 pm
If a ramp always started on the "far side" of a tab how would the far side of the tab ever get cut vertically?
jenordyke
Re: Ramps and Tabs
Post by jenordyke »
Ummm, by ramping down while moving forward, getting to depth, and then "backing up"? If a flat bit without center cut needs to ramp in at the beginning of a 1/4 deep profile cut, it needs to ramp in before continuing that cut on the 'far side' of the tab, doesn't it?
jenordyke
Re: Ramps and Tabs
Post by jenordyke »
Thank you, Martin.
