Turn off Malwarebytes before installing.
VCarve Desktop & Pro Version 11 are OUT NOW
- SteveNelson46
- Model of CNC Machine: X Carve 750
Re: VCarve Desktop & Pro Version 11 are OUT NOW
Edition Windows 10 Home
Version 21H1
Installed on 14/10/2020
OS build 19043.1110
Experience Windows Feature Experience Pack 120.2212.3530.0
I'm also running Sophos Home Premium, No Errors or warnings when installed.
I don't have Malwarebytes installed
I have uninstalled it agaim and reinstalled it on a different drive.
Still doesn't work
I'll try downloading the files again from the Portal and try a new install
***Update***
i uninstalled it , reinstalled it went to Sophos add on Apps and included it and now it works.
Usually i've found sophos giving a warning on install, but this time nothing,
Thanks everyone for your help, it was very much appreciated
- Model of CNC Machine: piranha FX
Need help with this error message that pops up when I open the version 11 desktop. I need real step by step guidance to fix it.
POST_BASE error: see viewtopic.php?f=18&t=37978
Same problem as daz2264.
VCarve won't start if Sophos Home Premium is active.
When i stop Sophos, VCarve will run...
I don't want to stop my virusscanner...
Can't you add VCarve as an allowable program? I don't use Sophos but I've never come across a virus scanner program that doesn't let you do that.
In Sophos i have excluded the entire directory...
This is what the other guy said he did to get it working.
I have read it, opend Sophos Home Premium, and searched for that option.
Could not find it though...
- scotttarnor
That did the job! Thanks!!
hi i am having trouble loading my updated V11 to my computer. it is an older model running windows vista. the problem is i am unable to load / open the V&co page
Wayne.
Wayne.
What error are you seeing when you're trying? What browser are you using and what version of it ?
i updated my browser and it seemed to work ok. Thanks
- Model of CNC Machine: 3 axis router
I have version 11.008 running on my laptop, when I log into the website it tells me that I can now download version 11.
For clarity, is this a revision to version 11.008? or something that is just part of the web page.
Also how do I know when an update is available to the version I am running and can download just the update or do I have to download the whole program?
Many thanks
Michael.
Many thanks
Michael.
