VCarve Desktop & Pro Version 11 are OUT NOW
SteveNelson46
Re: VCarve Desktop & Pro Version 11 are OUT NOW
Post by SteveNelson46 »
Daz2264 wrote:
Fri Jul 23, 2021 1:38 am
I too have downloaded it. Seems to download ok and install ok but won't start up.
Tried runing it as admin and still wont start.
Any ideas?
Turn off Malwarebytes before installing.
Daz2264
Model of CNC Machine: X Carve 750
Post by Daz2264 »
Adrian wrote:
Fri Jul 23, 2021 8:43 am
Daz2264 wrote:
Fri Jul 23, 2021 3:12 am
Nothing happens. No error messages, nothing. ??
i have uninstalled it, rebooted and reinstalled it.
The VTransfer seems to open up and the Browse VCarve link is ok but not the program
What version of Windows are you running? Do you have an antivirus running that might have blocked part of the install or needs you to allow the program to run?
Edition Windows 10 Home
Version 21H1
Installed on ‎14/‎10/‎2020
OS build 19043.1110
Experience Windows Feature Experience Pack 120.2212.3530.0
I'm also running Sophos Home Premium, No Errors or warnings when installed.
I don't have Malwarebytes installed
I have uninstalled it agaim and reinstalled it on a different drive.
Still doesn't work
I'll try downloading the files again from the Portal and try a new install
***Update***
i uninstalled it , reinstalled it went to Sophos add on Apps and included it and now it works.
Usually i've found sophos giving a warning on install, but this time nothing,
Thanks everyone for your help, it was very much appreciated
meremortal
Model of CNC Machine: piranha FX
Post by meremortal »
Need help with this error message that pops up when I open the version 11 desktop. I need real step by step guidance to fix it.
Post by adze_cnc »
POST_BASE error: see viewtopic.php?f=18&t=37978
maja158
Model of CNC Machine: none
Post by maja158 »
Same problem as daz2264.
VCarve won't start if Sophos Home Premium is active.
When i stop Sophos, VCarve will run...
I don't want to stop my virusscanner...
maja158 wrote:
Thu Jul 29, 2021 9:17 am
Same problem as diaz2266.
Can't you add VCarve as an allowable program? I don't use Sophos but I've never come across a virus scanner program that doesn't let you do that.
maja158
Post by maja158 »
In Sophos i have excluded the entire directory...
maja158 wrote:
Thu Jul 29, 2021 10:37 am
This is what the other guy said he did to get it working.
maja158
Post by maja158 »
I have read it, opend Sophos Home Premium, and searched for that option.
Could not find it though...
scotttarnor
Post by scotttarnor »
Try this
Scott T
@scottscnc
maja158
Post by maja158 »
That did the job! Thanks!!
zac
Model of CNC Machine: shark pro
Post by zac »
hi i am having trouble loading my updated V11 to my computer. it is an older model running windows vista. the problem is i am unable to load / open the V&co page
Wayne.
zac wrote:
Sun Sep 19, 2021 1:35 am
Wayne.
What error are you seeing when you're trying? What browser are you using and what version of it ?
zac
Post by zac »
i updated my browser and it seemed to work ok. Thanks
Michael2021
Model of CNC Machine: 3 axis router
Post by Michael2021 »
I have version 11.008 running on my laptop, when I log into the website it tells me that I can now download version 11.
For clarity, is this a revision to version 11.008? or something that is just part of the web page.
Also how do I know when an update is available to the version I am running and can download just the update or do I have to download the whole program?
Many thanks
Michael.
