Post Processor not working
Hello, im new here to the forum
We have a Giben G4 EVO and a Laguna SmartShop 2 here at the shop, we do mainly cabinet boxes ( kitchen, bath etc) and closets, this is the first job ill be needing a software like V Carve. Ive always used Cabinet Vision and cabinet making software for my softwares.
I designed the molding we need for this job, saved the toolpaths with the " Laguna SmartShop BR ATC" post processor and it worked fine, then i saved with the " Giben G4 510 Arc ATC inch" post processor. i believe everything worked except the Z height that was messed up.
I created a new job, 21” wide 6” high and 2” thick, one profile toolpath across the part with 1” deep. I copied the same toolpath 2 more times, each toolpath using a different tool bit. Tool#1 using 3/8” compression. Tool#2 using ¼”downshear. Tool#3 using 3/8” downshear.
All toolpaths should lower 1” from the spoilboard on the ideal scenario, but..
Tool #1 lowered to about 1 7/8” from the spoil board.
Tool #2 lowered to about 1 3/4” from the spoil board.
Tool #3 lowered to about 4” from the spoil board!
I sent this to the support email last week but i guess no one figured out why this happened. I don't know if I'm missing something simple on the software, but when i preview the toolpaths the 3d shows me exactly what i need, and since its working fine on my laguna im assuming this is something with the post processor.
Anyone has any ideas? Anyone has a Giben?
I would appreciate the help! Thank You!
Re: Post Processor not working
In this case viewing the g-code file (the one that is sent to the cnc machine) would help. If all the Z moves in the g-code correctly go down to 1" below the surface then there is something wrong with how you specify the tools on your machine (which is what I suspect).
- TReischl
+1 on learning to read g code. Saves tons of guessing when things go wrong.
It is not complicated when it comes to the motion commands.
These are the 3 gcodes i just tested. 3 different tools using the same line i drew, doing a profile toolpath, 1" deep, using the same post processor. My material was 2" high, so all tools should be 1" from the spoilboard, but the same thing happened
Tool#1 ended up 1 7/8" from the spoilboard
Tool#2 - 1 3/4"
Tool#3 - 4"
Since i have the post processor i use for cabinet making software, would that be of any help to check if there are any differences with this on in vcarve? And could this post processor work in any way in vcarve software?
Sorry if its a silly question, this is really out of my area
Tool#2 - 1 3/4"
Tool#3 - 4"
- Model of CNC Machine: stepcraft m1000
If i read your gcode files correctly you are calling for tool 3 in the H register and telling machine to use tool 13 hope this makes sense.
The tools are displayed like that on this machine, i believe its because it has a drill block (multi drill), so my tools on the spindle are 11 for tool #1, 12 for tool #2, 13 for tool #3.. etc
I recreated the same part and operation on my cabinet making software, im sending it attached.
I hope this helps
And i really appreciate you guys trying to help me out!!!
I hope this helps
- Tool1Mozaik.txt
- (609 Bytes) Downloaded 39 times
Yup, all 3 files are going to 1" depth.
1st line goes "in the air" to XY position 0.20" above the 2" material thickness (2.20 in total)
2nd line goes down to 1" above machine bed.
Only difference in the 3 files is that tool2.txt uses F20 as speed in line 2,
It's probably something to do with how your tool lengths are specified on the cnc machine. Luckily it didn't plunge into the machine bed.
Code: Select all
G0 X0.1233 Y-3.0000 Z2.2000
G1 Z1.0000 F200
Thats good that the gcode is working
I just dont understand why on cabinet making software it apparently doesn't specify anything different for the Z height.
Ill keep trying different things here and let you guys know! And if anyone has any ideas of tests let me know
- sharkcutup
I know that this may be a redundant question BUUUUTTTT --- How is the Z-zero being set at the machine after each tool change (bit change)?
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
I expect Steven is on the right track. It's probably to do with tool length compensation.
From your previous posts you seem to be saying that the Vectric files are using tools 11, 12 and 13. They aren't they are using 1,2 and 3 instead so check what you have the tool numbers set to in the tool database. The cabinet making software file is using tool number 11.
Success!! On both g codes ( from cabinet making software and VCarve) it indicates "T11", which is my tool #1. But on cabinet making software it then says G43 H11 Z2.
and Vcarve says G43 H1 Z3.0000. So i just manually changed the "H1" to "H11" and it worked! I tried setting the tool number on vcarve to #11 insted of #1, but then it shows "T111" as tool selection, so i believe there is something on the post processor that changes that H1 to H11.
Ill do some more digging to see if i change this, but worst case scenario since for this job ill only need 3 different gcodes i can change them manually.
Thank You ALL for the help!
God Bless you all
God Bless you all
Quick update, i compared the two post processor VCarve (Left side) vs cabinet making software (Right side), you can see the attached image, the simplest thing was causing me such a pain..
Just added the "1" between the H and [T] and voila, its working!
