Vcarve Pro Update losses tool database
I updated my Vcarve Pro today with patch from Vectric. After updating I noticed my tool database has lost all of my tools that I input. It also happened on my last update. What am I doing wrong , is this common, how can I prevent? I did a search of the forum and could not find anything. TIA. Terry
Re: Vcarve Pro Update losses tool database
A patch shouldn't make any changes to the tool database, if one has then you would be best contacting vectric support directly, I have been using the software since version 7 & never had a problem when installing a patch. If you are updating to a newer version however using a completely fresh instal then you will need to migrate your tool database from the previous version.
If you open the software & look under the help tab towards the bottom you will see an option to migrate from previous version, bring up this option & there are a range of things you can migrate from your previous version of the software.
What version of the software are you running? In the tool database folder there should be a back up copy of the tooldatabase, I also use the option to back up to the portal
- sharkcutup
Saving your tool database to your portal with Vectric is a safe bet. You upload your tool database using the functions within the tool database. Anytime you make changes or add new tools you save/upload it to your portal at Vectric. It will always be there whenever you need it!
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
