Hi
Have watched the video about making a shoehorn on cnc and wonder if anyone can help me set up a toolpath for this?
Shoe Horn
Re: SHOE HORN
Do you mean the New Brit Workshop one?
The toolpaths are in the files already. You just need to adjust the feed rates for your machine.
- Model of CNC Machine: Nigthhawk cnc
Re: SHOE HORN
it it just for one side toolpaths, i wounder if i coud use a 2 sided jobb for this?
Re: SHOE HORN
The full CNC cut file is two sided with toolpaths but for some reason they've done that one file as an Aspire (CRV3D) file rather than VCarve (CRV) as all the other files in the project are which is probably why you haven't seen it.
Not sure why they did it like that as it should work as a VCarve job as well.
- sharkcutup
Re: SHOE HORN
I do not have ASPIRE so I made my own adjustments so that I could make one from V-Carve PRO which I own!
I created my own model (basic shape) from the .dxf files supplied then added a slight dish to the foot heal portion in my two-sided project file. I also used the moulding toolpath to add a slight curvature to the backside too!
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
Re: Shoe Horn
it looks great ,i also have the vcarve pro . Do you want to share your setup for this shoe horn ?
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
Re: Shoe Horn
Russell Crawford
- SteveNelson46
Re: Shoe Horn
Very clever indeed, Russ.rscrawford wrote: ↑Thu Jun 10, 2021 1:21 amHere's my version of a shoehorn made on the CNC.
https://www.youtube.com/watch?v=kqNz2VvSRu0
Re: Shoe Horn
Is there anyone that have the 2 sided jobb toolpatch for vcarve pro and not just for the aspire??
someone with aspire that can save it like a vcarvepro file and share it with me?
