I am running VCarve Pro Shopbot Edition and recently installed the software from the portal.
The new installation seems to be missing files. I was able to find and copy the postpocessor file OK but I get an error when I try to import a tool database. (.tool file).
Shopbot support helped me with the post processor file and suggested that any file in the tool database folder might interfere. There was a .txt file in the folder that I deleted and then tried to import the .tool file again and got an error. Thoughts? I was able to create one new tool and use the defaults but I feel more confident with a library.
Error loading tool database
- Model of CNC Machine: ShopBot Desktop
Re: Error loading tool database
The tool database has a .vtdb suffix. The .tool is for an exported file created from an older version of the software.
What error are you getting when you try to import the file?
I am running the VCarve Pro Shopbot version and it is only v7.514
When I click "import" in the tool database menu, it is looking for a .tool or .tool_db file, which is what I was sent from shopbot today.
The error reads
"Failed to load tool database from file"
The error reads
Must be something corrupted with the file I would think. I just exported from VCarve 7 into VCarve 10.5 without any problems. Here is the file I used so you can see if it works for you. You'll have to unzip it as the .tool file type isn't supported on the forum.
- v7 metric test.zip
- (4.77 KiB) Downloaded 83 times
Thank you! Yours worked. I tried several of the ones directly from shopbot support but they all fail to load. I wonder if there is a repository of files somewhere on the shopbot wiki or forum. Maybe it is something in the downloading from Dropbox.
Maybe you would be so kind as to post a .zip file of some one in inches for the lame American who still can't commit to metric? I suppose I can tweak the defaults that show up when I create a new tool but it would be nice to have some basic ones to work with.
Here it is. Remember that is just a set of defaults that came with the software. You still have to make sure the settings make sense for your machines capabilities.
- v7 imperial.zip
- (5.38 KiB) Downloaded 56 times
Thank you! I will heed your advice but it is nice to have a stepping off point.
