I would like to add my logo to my job set up sheets in place of the vectric log
Is there a way to do that.
Thanks Jeff
How to add my logo to the job setup sheet
Re: How to add my logo to the job setup sheet
Go to the Gadgets menu and choose Setup Sheet Editor. The first option lets you set your own logo.
- Model of CNC Machine: Shapeoko 3D XXL
Thanks You Jeff
When I go to the job set up sheet
Change logo says image will be scaled to fit 165 x 52 what do those mean .
That it will increase or decrease my logo to fit
Here is a file of my logo
When I put that in it is too small for the logo area.
Any ideas on what to do.
Jeff
Jeff
It means it will be scaled to 165 pixels by 52 pixels.
You've got a lot of dead space in that image. If you crop it so it's just the logo then it will display much better.
Now that you say that I can see where that should make it bigger
Thanks For the help
Jeff
Thanks For the help
Jeff
