Need some help with creating the tool paths for my logo. When I try to input the photo and have it traced I just get weird pockets of engraving. Appreciate any help.
Zach
Need help with my logo
- Model of CNC Machine: Axiom Precision AR8 Pro
- scotttarnor
Re: Need help with my logo
You need to share the file or individuals have no idea what you are trying to achieve or how you are trying to accomplish it.
Scott T
@scottscnc
@scottscnc
Perhaps you might look at things from the other end of the chain. Rather than start from the image (JPG being horrendous to work with) being converted to vectors how about starting with the file, probably vectors, that created the image?
- FixitMike
did a bitmap trace (black and white) from the posted image and got what I consider to be a quite satisfactory image. the Fitting curves to Vectors tool made it even better. The vector valicator tool did show some overlaps that needed to be fixed. .Note that if you don't fix overlaps, the VCarve toolpath can go crazy. Also the pattern on the side involves some very fine gaps that only a VCarve toolpath with a sharp bit will give you a decent picture
- FixitMike
-bit
Appreciate the help.
Apologize didn’t even think to add the vector file instead of the picture
- Model of CNC Machine: shopbot desktop
Hey Mike that looks good enough to carve.
- Model of CNC Machine: Homemade
