How to measure 3D Objects?
- Model of CNC Machine: 4x8 Avid Pro
I imported an .stl created in Sketchup into VCarvePro, and when I ran the 2 sided job the part was much thinner than I expected it to be. I opened VCarve to check it and I can't figure out how to measure the object? I can click on it and see the W and H, but not the thickness? I know I can see the thickness of the workpiece, but not the completed piece? Any way to do this?
www.foothillcustomfurniture.com
- mezalick
Re: How to measure 3D Objects?
In the " Measure/ Inspect" tool there is an option the draw a vector of the model cross section.
That will show the Z height of the 3D model.
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Thanks for the response, but what am I missing? I still only see X and Y measurements? Thanks!
- scotttarnor
Did you right click on the points you want to measure?
Scott T
@scottscnc
@scottscnc
- highpockets
- jfederer
- Model of CNC Machine: CanCam D23M
I saw a tip here on the forum recently which I have found invaluable. If you hold down the CTRL key and hover over the simulation image, the normal XY display in the lower right adds Z. This has saved me from your kind of problem on my current project.
Joe Federer
www.federer.ca
www.federer.ca
That tool creates a 2D cross section of the 3D shape between the two points you select so the vertical height of the 2D vector created (Y axis in this case) reflects the Z height of the 3D.FoothillFurniture wrote: ↑Sat Mar 20, 2021 3:59 amThanks for the response, but what am I missing? I still only see X and Y measurements? Thanks!
- highpockets
As Adrian said, the problem is on a two sided job it only does one side, you'll need to the cross section on both sides and add the results to get the full depth of the Component.
