I'm receiving an error message stating that " the current tool path file would move 1.126" above axis limit with current offset"
just starting out of the box with CNC programming, looking for answer how to correct. I'm not sure if this is Vectric or Onefinity problem.
Any help to correct or point me in the right direction will be appreciated.
Tool Path Info Y axis
- SteveNelson46
Re: Tool Path Info Y axis
Hi Steve
I figured out what the problem was. I was creating a waste board 30"x30". I created array of holes to hold T-Nuts in V-Crave Pro.
I drawn a x marking the center of the waste board.
I then moved the machine spindle to hoover over that center mark. When I pushed the play button to start the g code. That is when I received the error message. What I didn't take into accord, was the offset of the spindle to the center of the the x rail. thus creating the error.
When I made the offset adjustment everything work fine.
Thanks for answering back
PS we vacation last year in Tucson when Covid hit. Everything shut down, that really sucked. It looks like a beautiful city.
