I recently built a replica of a Model T pickup truck. I'd like to find an antique model gas pump source to buy a pump to display with the car.
Any help is appreciated.
Phil
Off topic antique model gas pump source
- scotttarnor
- Model of CNC Machine: AVID PRO4824
Re: Off topic antique model gas pump source
I thought you were talking about a full size vehicle. I was gonna say, no pump but I've got some "actual" antique parking meters.
Isaiah 41-10
I did a 1930 Duesenberg that had a old gas pump, but it was years ago and I can't find the file. If you look at the attached picture, it would sure easy to model.
Gary
Gary
Great job on the Duesenberg. The gas pump looks like it would be a good choice for my Model T. Any idea how tall the gas pump is. I've found sources for 5" tall pumps and I'm not sure that is tall enough. Your pump looks fine with the Duesenberg.
Phil
Phil
If I remember the base of the pump was 1/2" thick, so by scaling the picture in Rhino, the pump should be 6" tall. Of course the car is only about 4" tall, so if your Model T pickup is larger, I would make the pump larger.
The Model T that I built is about 6" tall, so I would put the height of the pump maybe 7" or whatever looks good.
Gary
Thanks, Gary.
Phil
Phil
- highpockets
Found this one on Thingiverse https://www.thingiverse.com/thing:3032245
Imports and slices well...
Thank you, John. Looks like a winner.
Phil
Phil
