Moulding toolpath
Moulding toolpath
Hi all, I am trying to create the coin bank from in the lab with Todd. I need to change some settings. Mainly material thickness to 1.5". when I do that the Moulding tool path leaves a flat bottom then starts the curve. Just by changing the material thickness shouldn't the software recognize that and adjust the tool path? Any ideas? Thanks, Jeff
- SteveNelson46
Re: Moulding toolpath
Did you check the position of the model in the material on the toolpath tab? Also there is a toolpath position in the moulding toolpath itself.
- highpockets
You'll need to adjust the dimensions of the profile vector in order to accommodate the thickness difference. The software doesn't do that automatically.
- highpockets
I looked at Todd's coin bank, it doesn't use a Moulding Toolpath, that I saw. Look at modifying the height of the Dish Component.
Update: instead of modifying the Dish Component just change the cut depth on 07 - Pocket - Center - .245EM from .55 to .85.
