Need Saxophone Image
Looking for saxophone image for a project of mine. Need something in 4 to 5 inch range. Have not been able to find.
- adze_cnc
Re: Need Saxophone Image
Perhaps some more information?
There are thousands or even millions of images of saxophones out there. Help us limit those to ones we have / know about.
Do you want just vectors, or a 3D model?
Which saxophone: soprano, also, tenor, baritone? Alto and Tenor are the two most common.
(Yes, I'm a recovering saxophone player and I worked in a music store.)
- mezalick
I have this 3D model.
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- Model of CNC Machine: Onefinity X-50 Woodworker
Search on Thingiverse.com. Here's the first srl model I found with a quick search.
What I am looking for is a single sided 3D model. We have neighbor that puts on annual (Fred Stock) on each Labor Day for our neighborhood and last year may be the last year he puts on. He plays the Sax and wanted to do a thank you plague with a 3D Sax on it to thank him.
Something like this?
I just imported a model from Thingiverse (https://www.thingiverse.com/thing:4750751). With the import process I needed to resize it to fit the project, rotate it in order to get it correctly oriented in the project and then set the depth setting to model just the top half of the sax. Getting the model oriented for import is a little bit tricky until you get the hang of it.
But now that I look more closely you're using VCarve so I'm not sure that the 3D modeling tools are available to you. I'll try to upload the model from my previous post if that is what you're looking for.
