I went to start a project, used my z axis plate like I have done 1000 times. loaded the program into the machine and when I press start it goes to the first position and starts its carving pass but 1/4 in above the surface. What have I done wrong?
It is quiet possibly not 1/4 inch but it is not touching the surface
setting z axis
- Model of CNC Machine: next wave shark 520
Re: setting z axis
Have you got the z-zero position set correctly in the Job Setup in VCarve?
Re: setting z axis
yes sir I do. I even tried it on two separate jobs with the same result
- sharkcutup
Re: setting z axis
Did you make change to your carving program, re-calculate your toolpaths for the changes made and saved them with the correct post processor for machine use?
Or
Is a the same .tap file you have used over and over again maybe a 1000 times? Could it be corrupt? Have you tried saving the toolpath file again using the Correct Post Processor again and using it at the machine?
How are you setting your z-Zero at the machine?
Just some thoughts!
Sharkcutup
Or
Just some thoughts!
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Re: setting z axis
thanks for the suggestions cut up... when I referred to using it over and over 1000 times I was talking about the z calculation plate.
both files that I tried were both new tap files that I just programed within the last month. one I have used successfully and the other, I had yet carved with
I try to learn something every day
- sharkcutup
Re: setting z axis
Okay Where are you placing the calculation plate (touch-off plate)? Top of material or machine bed?
Also have you checked to see if somehow the thickness setting for the calculation plate (touch-off plate) may have changed?
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Re: setting z axis
top of material. the plate was bought with my first machine. and have used it successfully on the 520. what else possibly could have changed
Re: setting z axis
sorry I just thought of something. I'm not aware that you could change the thickness of the touch plate
- sharkcutup
Re: setting z axis
In Earlier Versions of the shark it is located in the preferences of the control panel. It is a one-time setting and over time most forget about it until they get a new touch plate which is different in thickness.
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
