excessive carve time
- Model of CNC Machine: next wave shark 520
I bought some art work on design and make (in the magical gardens) and I wanted to make the hobbit door, It estimated the carve time at 23 hours for the roughing pass Is that possible? and another 6 hours for the finish pass. I wanted to make it 24X9 is that what is causing it?
- Todd Bailey
- Vectric Staff
- Model of CNC Machine: CraftCNC
Re: excessive carve time
Hello...
Thanks for the question.
Well, there are probably a few things in play here. The times that software gives you needed to be corrected to real-world times from parts cut on your CNC. I would suggest first making sure they are close by cutting a small part and adjusting the Rapid Rate and Scale Factors - https://docs.vectric.com/docs/V10.5/Asp ... index.html Try to match the times as close as you can.
Second... I would look at the size of the tools you are using. Are the tools set-up correctly? Are you using a small tool that could be swapped for a larger one? Any toolpath optimization you can add in?
If all that fails to get you a better time then of course size it down a bit if that is an option.
I do think that time is very excessive... and you might want to send the file to the Support team and let them have a peek. Or feel free to send it over to me at D&M - info@designandmake.com.
Todd Bailey | Design and Make
DesignAndMake.com
DesignAndMake.com
You have already asked this question & had some feed back, asking the same question multiple times doesn't really help anyone, best to use your original post if you are seaking further help.
- adze_cnc
That other post is at: viewtopic.php?p=262871#p262871
