Text on tree of life vectors
spud321
Model of CNC Machine: shapeoko 3 xxl
Post by spud321 »
I have watched quite a few tutorials about text on text where you convert to curves to get layers to weld properly .
I tried this method with a sign I am trying to make . The bottom layer has the tree of life vectors and the top layer has a name in text .i can convert top layer to curves but when I try to convert bottom layer the option for convert to curves is greyed out ?? When I check bottom layer for vector validation I found some open vectors ? Is this causing the option to convert to curves not to be active?? Do I need to fix those vectors first ??
Re: Text on tree of life vectors
Post by Rcnewcomb »
Can you upload your CRV file? That helps eliminate a lot of random guessing.
How do I upload files or photos to the forum?
10 fingers in, 10 fingers out
another good day in the shop
Post by martin54 »
There can be all sort of problems caused by free download fonts if that is what your bottom layer font is, I never use them for that reason.
As Randall says it's difficult to know without seeing the file but you could start by fixing the open vectors problem, won't do any harm & good practice :lol: :lol:
SteveNelson46
Post by SteveNelson46 »
If I understand this correctly, converting to vectors is for fonts only. The Tree Of Life is already vectors.
spud321
Post by spud321 »
download/file.php?mode=view&id=75968
here is the crv file , i did a new tree of life layer made with clip art and the vectric trace bitmap option . no issues with open vectors now .
my intention is to have the text on top layer above the tree???
tree of life sign.crv
(588 KiB) Downloaded 43 times
Post by martin54 »
SteveNelson46 wrote:
Thu Oct 22, 2020 5:56 pm
Think you might be right Steve :lol: , I thought he had 2 lots of fonts as you get with stacked text & then the tree of life vectors, one of the fonts had converted but the other font had not hence the coment about free downloaded fonts :lol: :lol:
sharkcutup
Post by sharkcutup »
Like so???
Manually trimmed using trim tool for both top and bottom layers. Had to ungroup the tree of life vectors and the font vectors. Also Converted fonts to curves.
Sharkcutup
www.hoganscnccrafts.com
One on One V-Carve Help is Available!!!
Private Message me for details!
