inlaid golf ball
- Model of CNC Machine: Shark 5.0
inlaid golf ball
Need to cut a sphere into a plaque to hold 1/2 of a golf ball. The ball will rest in it. I know I should be able to figure this out but having trouble. Can anyone point me in the right direction? I'm using VCarve Pro. Thanks!
- Tex_Lawrence
- Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 11.554
Re: inlaid golf ball
There was a recent thread about this "bowl" shape, but the jist of it was to use the moulding toolpath.
The "secret" that I learned was to place a 0.005" circle at the center of your bowl for the drive rail, and then choose a 1/4 circle for the profile.
Tex — Crooked Wood Products
Could you use any of the supplied dome/dish models & just alter it's size to suit your needs?
- sharkcutup
Check out Design & Make
https://store.designandmake.com/search/ ... q=golfball
This may be what you are looking for
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
Thanks all! I’ll give it a try
- Tex_Lawrence
I read this as he needed 1/2 of a sphere as opposed to a textured golf ball in 3D.
- sharkcutup
Yeah Tex you are probably right!
1/2 of a golf ball will rest in this the other 1/2 sits above the wood surface
Sharkcutup
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
Since you can not see what is below the golf ball, why not cut a cylindrical pocket? Should not make a difference visually.
Maybe a tad undersized and you can squeeze the ball in without glue.
Puzzle, Finger Joint, Maze and Guilloche freeware at https://fabrikisto.com/tailmaker-software/
Tex, you are are correct. All I need is a 1/2 sphere. But I cant seem to adjust the depth of the supplied dome to seat the golf ball. Can anyone tell me the steps to modify the supplied 3D dish into a 1/2 sphere?
If not I'll give the molding toolpath a try...
Import the dome shape, set its size to what ever diameter you want, click on the modeling tab & then the wrench icon, set the combine mode to subtract & the shape height to what ever value you want.
Don't forget to add a zero plane if you cutting below the surface of the material.
Are you sure your not over thinking this? Does it need to be exactly half a sphere or just an indent you can glue a golf ball into? You could probably also use a small screw to secure it from the back but make sure its not one of those golf balls full of some sort of goo
I cut one open as a kid & sprayed some brown stuff up my parents living room wall, they were not impressed
If I understand correctly you want to mount a golf ball so that half of it is proud. If the plaque hangs on a wall, why can’t you simply cut a pocket of the correct diameter and depth and secure it in a dab of construction adhesive. It will look the same as a dish when mounted.
Tailmaker suggested that a few posts ago & to be honest if it were me that is plobably what I would do, I would think time wise it would be a lot quicker to cut a pocket rather than a 3D model even if you use quite a large step over for the modelWayne Locke wrote: ↑Tue Oct 13, 2020 2:20 pmIf I understand correctly you want to mount a golf ball so that half of it is proud. If the plaque hangs on a wall, why can’t you simply cut a pocket of the correct diameter and depth and secure it in a dab of construction adhesive. It will look the same as a dish when mounted.
Tailmaker, Martin54 & Wayne all provided the practical solution. And I appreciate it!
I'd like to learn how to do this by cutting a 3D dish model so I'm gonna try. It's just an embedded 1/2 sphere! Of all the challenges I've had over the past 5 years this task doesn't seem like it should be so big a lift. Going to try.
But if I can't do it, will take y'all's guidance and just cut a pocket.
OK I've just had a look at this & I'm not sure where you are going wrong, I imported a dome/dish model, resized it to 42.67mm which is apparently the diameter of a golf ball. Set the combine mode to subtract & checked it's properties. The model height is 21.183mm without me making any alteration so pretty close to half a golf ball as it ispjschwa wrote: ↑Thu Oct 15, 2020 1:02 amTailmaker, Martin54 & Wayne all provided the practical solution. And I appreciate it!
Use this model which is something like dish/dome90
set the combine mode to subtract, you can also set the shape height to exactly half the diameter, or even the radius if you like
Don't forget to add a zero plane if your model is set to subtract, helps to define the material surface & give a nice edge to your model
Thanks Martin. I downloaded a trail version of Aspire and it worked. In VCarve Pro it did not. It looks pretty good in the rendering so I may just leave it at that and see how cuts in the AM.
Though when I selected the 'zero plane' button as you suggested everything went haywire. Any tips on that?
